Old 02-24-2019, 09:29 AM   #1
Hev
Slide out not moving smoothly
We have a 2017 Heritage Glen Ultra Light with single living room slideout. The slide doesn’t move in and out very smoothly - it’s a little, I guess the best way to describe it is “jumpy”. Is this normal? On another note, which may be related, we have a torn side wiper seal. It is now out of warranty. Are these seals hard to replace? Should we be lubricating the slide mechanism in any way (was not instructed to do so by dealer when we purchased). Thanks. Dealer is not much help except to estimate about $500 to replace wiper seal.
Hev is offline   Reply With Quote
Old 02-24-2019, 10:42 AM   #2
Bill and Gail's Avatar
I buy the lubricant spray for rv slides, and spray the slide tracks every couple of months. I also have a torn wiper seal, it looks as if they just pull out and the new one slides in, take a good look at yours first. You have to order the right one, mine appears to be part of the seal.
Bill and Gail is offline   Reply With Quote
Old 02-24-2019, 10:55 AM   #3
I would check to make sure the slide out is properly aligned, like it is in the middle of the opening. My slide was not aligned properly and tore the seal. I had to align it myself. Not hard to align and replace. I bought mine at Steele Rubber company online. They are between 2 and 5 dollars a foot.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is online now   Reply With Quote
Old 02-24-2019, 11:03 AM   #4
Who Dares, Wins
doc73's Avatar
What kind of slide mechanism is it? Some, like the swintec slides, need to be kept aligned by holding the buttons a few seconds after they are all the way out or in to "align" them. We just use the slide out lube made by camco to the mechanism every so often.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-24-2019, 11:06 AM   #5
Hev
From what we can see, our slide doesn’t have a track? There are just 2 white rollers it moves in and out on? Thanks for your response.
Old 02-24-2019, 11:09 AM   #6
Who Dares, Wins
doc73's Avatar
So no tracking along the sides or cables? How about underneath us there any tracking?
2015 ChevyHD D-Max
Old 02-24-2019, 11:11 AM   #7
Who Dares, Wins
doc73's Avatar
Make sure. The rollers are free spinning and not gunked up with dirt.
2015 ChevyHD D-Max
Old 02-24-2019, 11:26 AM   #8
Look underneath and see if you have, what is called, a rank and pinion mechanism.
My thinking is, make sure the slide is aligned properly. Meaning, measure the distances between slide ends to the wall opening, should be the same. I can take pictures on what I am talking about if needed. Good luck.
2008 Honda CR-V
Old 02-24-2019, 11:29 AM   #9
Herk7769's Avatar
Our Flagstaff's dining room slide has only one rack due to its small size.
It wobbles like crazy going in and out.
I am also curious how long it will stay in sync.
HAM CALLSIGN - KC3FFW
Old 02-24-2019, 05:19 PM   #10
I also have the single track on the underside. It does move a little "jerky" but it just pivots up and down a little. Dealer says that is normal.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
slide, slide out
