Old 03-07-2011, 09:57 PM   #1
slide out not working
We can not power up our slider out no power to the motor, our the switch on the wall doesn't seemed to have power where do i start to analyse this problem
jamesroof is offline   Reply With Quote
Old 03-07-2011, 10:09 PM   #2
http://www.eaa1358.com/Passport/Slid...ideout-Web.pdf
Go here and this is the full manual for the Lippert Slide systems.
polkatronron is offline   Reply With Quote
Old 03-08-2011, 06:27 AM   #3
Herk7769's Avatar
There is a 30 amp fuse for each frame mounted slide located within 18 inches of the battery. There were three green pigtail fuse holders located BEHIND the battery box in our 5th wheel. One for each main slide and one for the front landing gear. I replaced all three with auto-resetting 30 amp fuses from AutoZone. DO NOT BREAK OFF THE TABS on the fuses. You will need all three sections to clear the pigtail sides. You will not be able to close the waterproof cap with the new fuses in place, so wrap them with a piece of "splicing tape" or electricians tape.
HAM CALLSIGN - KC3FFW
slide out
