Check the circuit breakers
In my Cedar Creek 5th wheel, there are mini circuit breakers that control the hydraulic pump that powers the slide-outs.
The following applies to my rig, and may also apply to yours:
If either or both of the levelers or slid-outs stop working, you may have tripped a circuit breaker.
1.If you hear a click, that means the solenoid is telling the motor to start/stop. If the motor doesn’t start, a circuit breaker has probably tripped.
2.There are 3 breakers hidden behind a shroud in the nose storage compartment.
3. They look like tiny buttons inserted into a gray housing.
Simply push in the button to reset the breaker. If the breaker had been tripped, you will hear a slight click.
The attached photo shows my circuit breakers
