Old 03-01-2014, 08:18 PM   #1
slide out not working
I have a 2008 georgetown xl 315 both slideouts will not go out - vehicle is parked - emergency brake is on and unit connected to shore power, batteries are charged full - have checked all fuses - when switches are operated there is no sound and no motion - on the road in North Carolina - can anybody help? thanks
angela85 is offline   Reply With Quote
Old 03-01-2014, 09:00 PM   #2
Brother Les's Avatar
Give you a bump.
Know nothing about your unit. How long have you had it? Ever happen before. What kind of slide out mechanisms do you have? Is there a Manuel crank or is it all electric? Check all of your fuses for one that is popped. Did they work before you got 'on the road'? Do most/all of the other 12volts systems work at this time?
Brother Les
Old 03-01-2014, 09:10 PM   #3
jonrjen's Avatar
Is every thing else working? Have you checked to make sure that none of the GFI wall plugs need to be reset? It should not effect the slide out motors, but I have seen stranger things.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 03-01-2014, 09:13 PM   #4
jonrjen's Avatar
Is your transmission in the "N" position.
I'm trying to think of anything from my National Pacifica that would have kept the slide out from working...bear with me here.
2013 Wildcat 353LS
Old 03-01-2014, 10:09 PM   #5
Triguy's Avatar
I know you said you checked all fuses, and I assume breakers, but maybe this diagram will help. I'm thinking there is a breaker going to your pump that could be checked. Best of luck.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-02-2014, 07:17 PM   #6
We drove 150 miles stopped and tried slide outs again and they both worked, there might have been a piece of weather stripping caught in the bedroom one, have no idea why they started to work but seem fine now. Thank you for your help
Old 03-02-2014, 07:24 PM   #7
Ford Idaho's Avatar
Glad they are working for now.
You do need to have this looked at because the last thing you need is to have them quit while out and what ever the problem is will only get worse.
slide, slide out
