05-29-2012, 11:21 PM
Slide out of adjustment?
I just picked up my 2013 Salem T26BUDG today and I think the slide needs adjusting. I didn't notice until I got home but with the slide all the way in the inner most surface sits about 2" above the floor of the non-sliding part of the trailer. This can be seen by lifting up the carpet on the sliding portion.
Is this what the two large adjustment screws extending downward from the end of the slide are for? I can just go back to the dealer but if it's easy I'm fine tackling it myself. I'd also just like to know how to do it for the future.
The only other things wrong so far is the table top is the wrong size and one of the window shades is too short. Neither a big deal. Overall, I'm pleased with the build-quality and overall product. Of course, I haven't really used it yet.
05-29-2012, 11:28 PM
Why don't you take it back to the dealer and see what they think. If it needs adjustment let the experts do it as per Forest River Warranty.
05-29-2012, 11:48 PM
As I said in my OP.... I'd like to know how to do it myself. 3 years from now when it happens again I can't take it back to the dealer. And, fwiw... It doesn't look like the "experts" got it right in the first place.
05-29-2012, 11:58 PM
I wouldn't touch it. Many post on here about torn flooring from slides. It's not supposed to be close to the floor when in, you don't camp in it that way. Changing those bolt heights on the outer edge, will change the angle when out, and may cause it not to seal, and therefore leak.
As for doing it yourself, probably a Lippert frame and slide. Look them up on the internet. They have directions. Proceed at your own risk.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
05-31-2012, 06:57 PM
Thanks windrider your search idea got the answer I had been meaning to find. Why does the non-powered side of the slide not go in as much as the powered side. There is a simple adjustment to synchronize the sides on the non-powered side...2 bolts should not throw any thing out of adjustment, besides close it all the way. Page 14 of PDF
http://www.eco-rv.com/scripts/pdfretail/get.php?id=366
HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
05-31-2012, 11:28 PM
If the outside flange around the slide is in tight and even at the top and both sides, the slideout is aligned properly. You don't want the slide-room floor contacting the other floor.
Dave
06-01-2012, 07:24 AM
mtofell; while I have a Rockwood it's still forest river. My slide does the same thing when in. What it is is that the top of the slide is coming in contact with the trl wall 1st then the rest of the slide is snugging up and sealing itself to the side of the trl. The slide out itself will tip up at the bottom in order to get a tight seal on the outside seals. It's just the slide sealing itself to the trl.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
06-01-2012, 07:33 AM
The slide is fine as long as when its in its sealing on top and sides.
Just go camping!
06-02-2012, 07:43 AM
Agree with the above. What you are describing is perfectly normal.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
06-02-2012, 08:06 AM
X3. I think you're fine, too.
When my slide is fully in it will sit slightly above the main floor. That is so it will be flush with your main floor when fully extended.
I've heard these called flat-floor slideouts—where the slideout mechanism is engineered to make the slideout floor at the same level as the main RV floor once the slideout is fully extended outward. However when the slideout is retracted, its floor is meant to be above the main RV floor.
But, if you think it's higher than you believe it should be in your unit, take it in or take pictures and send them to your service manager to confirm.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
06-02-2012, 09:22 AM
I would rather have 2 inches of clearance between the slide floor and the carpet, than have the slide rip out the carpet because it was too close!
