Old 08-06-2015, 11:32 AM   #1
Slide out on a 2013 grey wolf 29' trailer
Hi, I'm new to this. My question is: my slide out only works with the remote. Also my interior lights do not work. We have only used this RV once. we just put a new battery in, so it is not that. However it does slide out with the remote.
littlebit47 is offline   Reply With Quote
Old 08-06-2015, 03:31 PM   #2
I assume that you checked your 12V fuses in your electrical panel?? There are also probably fuses/breakers right around the battery someplace. They may look like little silver boxes with two exposed studs on them and they will have wires attached to the studs. Those little breakers can often be reset manually with a little black button on the back side of the breaker.
bruceatlam is offline   Reply With Quote
2013, grey wolf, slide, slide out, trailer
