Old 12-24-2017, 04:58 PM   #1
Slide Out Preventative Maintenance
What types of PM do you do for your slide outs?
ENGINEER is offline   Reply With Quote
Old 12-24-2017, 05:05 PM   #2
I thoroughly spray the rails with slide out lube at least once a year. Otherwise I just look to see that nothing looks broken or about to break.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 12-24-2017, 05:06 PM   #3
lmiken's Avatar
The users manual tells you what needs to be done. If you do not have one you can go on line and down load a copy. Usually lube the slide gaskets (rubber), lube the slide mechanisms (your manual will tell you the type of lube to use and how often).
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
lmiken is offline   Reply With Quote
Old 12-24-2017, 05:12 PM   #4
xgarys's Avatar
I frequently clean the top, bottom, and sides of the slide to protect the seals. I also treat the seals and lube the racks twice per year.
xgarys is offline   Reply With Quote
Old 12-24-2017, 10:01 PM   #5
Slide Out PM
Thanks everyone for your help. Great info.
Old 02-10-2018, 12:55 PM   #6
3-in-One Slide-Out Silicone Lube
Has anyone used 3-in-One RV Slide-Out Silicone Lube for their slide outs? Found this at Walmart and thought I would give it a try. I then looked at the Interactive Video manuals and it says it should have PTFE , or something like that in it. Don't see it on the 3-in-One can. Any Thoughts?
lbirdie123 is offline   Reply With Quote
Old 02-10-2018, 01:00 PM   #7
RV Education 101
Saw that it was used in RV Education 101 video. So it is OK to use!!!
Old 02-15-2018, 09:52 PM   #8
larry2c's Avatar
I'm a WD40 fan and they make this product with PTFE. Seems to work great and I can get it at Home Depot or from Amazon.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-09-2018, 01:07 PM   #9
slide acting up
When I move a slide out it goes ups as it goes out then comes down hard. Is something wrong?
jrmorris is offline   Reply With Quote
Old 04-09-2018, 01:14 PM   #10
Prime Member
Lube the rails with a spray on dry lube and treat the rubber slide seals.
Temporarily Camper-Less
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-09-2018, 01:23 PM   #11
Grammar Pedant
67L48's Avatar
Hey, I just wanted to thank those of you who have responded to the post. I'm also new to this game (my slide-out on my pop-up was in a different league) and I'm interested to see how you all handle this scenario ... and the specific products and cycles you use.
Again, just want to underscore that memorializing these practices help morons like me ... and others who aren't morons but just want to benchmark practices.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
maintenance, slide, slide out, vent
