Old 08-18-2018, 11:57 AM   #1
slide out problems
i have a 2010 rockwood with 2 slide outs i am having trouble with them and need help please! they will not let out when i try letting them out the slides all they are doing is clicking almost like they are slipping or something.i put in new battery i need help fixing these if possible
djt5170 is offline   Reply With Quote
Old 08-18-2018, 12:06 PM   #2
clr
Two quick thoughts first the battery may be low or weak. Is the unit plugged into shore power ac when you try this? Second have a second person push the out button while you watch the drive wheel cog below and determine if it is slipping. If it is slipping stop trying to put it out since at may pop the teeth off the gear.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-18-2018, 12:11 PM   #3
NMWildcat's Avatar
Sorry to hear about your slides. Im assuming they are electric gear driven slides. If you can hear it clicking, the fuses are probably fine. Is your new battery completely charged. Also, are you plugged into shore, generator, or truck power to assist the battery?
If power is good, then you might have a bad motor or gear. If you can move the slide manually a bit, it might get it past the possibly bad gear and then work with the button.
Let us know.
Scott and Liz - Southern NM
Old 08-18-2018, 12:17 PM   #4
thanks it is true that id i let the bedroom out manually i can push button and it will let in if i do not let it in all the way and back out
Old 08-18-2018, 12:34 PM   #5
is there any videos or help in removing gears for slide out to check them?
Old 08-18-2018, 12:40 PM   #6
NMWildcat's Avatar
We had an RV that acted similarly. I dropped the bottom so I could get to the motor and gearing. Turns out the gears were plastic! We went through several plastic gears until I could find some metal ones that worked.
I never found any videos for my particular RV, but you never know what a Google search will turn up
Also, it might be worth it to get an estimate from an independent RV service only shop. Could be a lot less than you think.
Good luck and let us know how it turns out.
Old 08-18-2018, 12:48 PM   #7
thanks my money supply requires me to do the work lol
Old 08-18-2018, 12:51 PM   #8
NMWildcat's Avatar
I hear you on that one!!!! Have a good day.
slide, slide out
