Old 06-12-2018, 09:27 PM   #1
Slide Out Question
I have a 2018 Surveyor 247BHDS and the sofa slide can only be moved via manual operation. Is there a fuse related to this? Batteries are fully charged. One slide works perfect. Any suggestions would be appreciated.
Kronacoz is offline   Reply With Quote
Old 06-12-2018, 09:39 PM   #2
ramit315's Avatar
Have you tried unplugging and swapping the switches?
2018 Ford F-450 DRW
2017 Sandpiper 379FLOK
ramit315 is offline   Reply With Quote
Old 06-12-2018, 09:53 PM   #3
I have a rock wood with two slides and just this past weekend I pulled the slide in at home and went to the mountains. When I got there I had the same issue, the small slide worked fine but the big one was dead. I cranked it out and started looking for the problem. Turns out a buddy had the same problem a few years ago and there are two inline fuses for the slides. Mine are located near the front on the drivers side. Under the trailer wall attached to the frame. A 35 amp dude and I was back in business. Hope yours is as simple as mine was.
Hoyt is offline   Reply With Quote
Old 06-12-2018, 10:02 PM   #4
Thank you Hoyt. I will take a look tomorrow and see what I can find. I appreciate the quick response !
Old 06-12-2018, 10:05 PM   #5
I have not tried that but when I took the cover off of the control panel, it looks like two different switches. I will investigate further. I just had the yearly inspection and maintenance and brought it home and found this issue. Thank You for the quick response and ideas.
Old 06-17-2018, 02:24 PM   #6
Did you ever solve your problem?
Old 06-17-2018, 02:37 PM   #7
Hello Hoyt, I tried about everything I could. I started to remove the screws that attach the mat to the underbelly. After removing six screws and not finding anything. I gave up put it back together and dropped it off where I bought it. For some reason the slide also came unadjusted so the top of the slide would seat and the bottom was still 2 inches out. If I cranked it all the way in, it was hitting the center island and compressing some of the wood on the island. I’m still trying to find a wiring diagram that shows where the fuses might be.
slide, slide out
