Old 12-26-2011, 08:53 PM   #1
Slide out question
I have a 2011 Wildwood and the slide out will sometimes get stuck when running it in. Its like the weather seal is sticking. Is there something to lubricate these?
Daniel
firedaniel is offline   Reply With Quote
Old 12-26-2011, 09:42 PM   #2
papap's Avatar
I pretty sure they sell a spray.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 12-26-2011, 10:05 PM   #3
Anacortesians
Daniel:
If it's a long vertical blade seal either on the underside or topside of the slide-out, you can hand-rub powdered graphite onto the surface of the slide, or use a srpay-on molybdenum disulphide luricant that dries.
I have an on-going problem with the underside seal on the bedroom of my MH and the moly spray is one of this off-season's projects. I'll be doing it to both top and bottom blade seals on both slides.
Frank and Eileen
No longer RVers or FR owners
Old 12-26-2011, 10:24 PM   #4
If it attracts dirt or can attract dirt, avoid it like the plague. There are many dry lube available for rubber seals. Personally I use ProtectAll to both clean and lubricate my seals. I do use a dry type lube on all of the slide mechanism I can see or reach.
Old 12-27-2011, 07:56 AM   #5
Herk7769's Avatar
Totally agree. Dry lube on anything metal that moves. Stuff collects dirt and mud as it is, no sense "welcoming it aboard!"
Silicon spray on anything else.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 12-27-2011, 04:55 PM   #6
why wouldn't you use silicon ? or does it attract dirt /
SALTY is offline   Reply With Quote
Old 12-27-2011, 05:22 PM   #7
Herk7769's Avatar
Pure silicon spray will not protect or lubricate the metal of the steps, slide bars, and rollers for more than one or two activations. Dry lube stays on the surface of the metal but does not attract dirt.
Silicon works great for lock mechanisms, hinges, drawer glides, and slide seals.
Old 12-28-2011, 09:52 AM   #8
Dallas Texas
TexasBBQ's Avatar
Lou - Don,
What dry lube have you found to be affective? I hear a lot about dry lubes specifically for the trailer market but my guess is others will work fine.
Cheers
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 12-28-2011, 10:34 AM   #9
Herk7769's Avatar
Just Google "Dry Lube for Slides" and you will get a number of good hits from Discounters like RVWholesalers. Any "Dry Lube" in a spray can will work. NOT Oil or Silicon for slide mechanisms though.
