Old 07-12-2010, 01:50 PM   #1
Slide out question
Can anyone tell me the way to adjust the slide out.... mine is sticking and binding. Also when it is in the floor is raised about an inch and where the table and sofa are they come off the floor around a 1/4 inch or so....Thanks for any imput
2006 FR/Wildwood 27BHSS
2006 Dodge laramie 5.9 CTD
northstarfire0693 is offline   Reply With Quote
Old 07-12-2010, 02:39 PM   #2
milzat's Avatar
Not sure what brand slide-out mechanism your trailer had, but below are a couple of links to slide room adjustment.
http://www.lci1.com/OwnersManuals/Sl...ideout-Web.pdf
Slideout Owner Manuals
http://www.mteccorporation.com/downl...frameslide.pdf
Hope that helps.
milzat is offline   Reply With Quote
Old 07-12-2010, 03:18 PM   #3
They are suppose to raise up about an inch- the slide out room rides on runners that drop down a ramp at the end of their travel, to allow the floor transition to be as flat as possible. The room is either pushed or dragged across the existing floor surface, and can be adjusted side to side, or tilt in or out; but NOT up! Hope this helps! Randy
Old 07-12-2010, 09:52 PM   #4
Hope that helps.
Thanks a lot.....thats what I need
Old 07-12-2010, 10:07 PM   #5
Cyber Phrenologist
Radio's Avatar
Here's the whole story with pics as to how I adjusted mine. The fun part was banging it with a big hammer!!
http://www.forestriverforums.com/for...ment-2630.html
As stated the slide out floor will float above the main floor about an inch when retracted. Try to avoid as much as possible (read: DO NOT) walking on the slide floor when retracted.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
