Old 05-05-2016, 04:17 AM   #1
Slide out quit
So many questions regarding slide outs but easier to just ask.
slide out will not move. There is a grinding noise as if the motor is trying to move the slide out but no movement. Same motor noise when slide all way in and you go to far. Not even sure if it has a manual way to slide out. Out of town working, wife was telling me about it. Going home this weekend to look. Thanks
Racer310 is offline   Reply With Quote
Old 05-05-2016, 07:58 AM   #2
Head Rambler
RV model number helps a lot. We don't know if it hydraulic or electric; schwintek, LCI, venture, etc. If it has one motor or two, etc., etc..
Since it's making a grinding noise it's probably the gearbox, but could be a pinion or rack gear. Hard to say without knowing a little more about it.
Gotta go campin!
Old 05-06-2016, 12:15 AM   #3
Thanks, I just know it is a chaparral Lite. Will be home this weekend to get more info.
Old 05-06-2016, 12:26 AM   #4
Check your battery charge level....
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 05-06-2016, 01:13 AM   #5
Thanks will do.
Old 05-06-2016, 02:20 PM   #6
MNtraveler's Avatar
Also could be a rock or pebble stuck somewhere in the tracks or underneath the floor. Or something obstructing movement causing the motors to grind - you know, a kid's toy or a dog bone.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 05-06-2016, 02:50 PM   #7
Is it out or in right now? If it's out, push on it hard and then try again. It may have gone too far. I've seen that happen before.
2017 Ford F450 Lariat 6.7L
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 05-11-2016, 03:27 AM   #8
Removed the belly and found that the 2 brackets holding the slide motor was bent. There are 2 tits that stick out of the motor slide that the brackets hold on too, well 1 of the tit had broken off which tells me the wife or daughter is holding the in/out button too long. Once I hand held the motor slide bar the slide worked in/out without issues. So now I bent the brackets back and have to find a welder to weld the little tit back on the motor slide bar--I guess that is how you would describe it. Out of town this week working so will have to check if it is metal vs aluminum.
Old 05-11-2016, 08:34 AM   #9
MNtraveler's Avatar
Typically the instructions say to hold the button for 2-3 seconds after opening or closing when there are full motors to keep them in sync. Not sure if you have duals.
2016 Forester 2401R
Old 05-13-2016, 12:56 AM   #10
Too Tall's Avatar
Shouldn't there be a limit switch to protect from over extension or retract?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
slide, slide out
