Old 05-14-2014, 04:58 PM   #1
want a Cat 293REX
Slide out rack & pinion gear lube???
Anyone used the EZ Slide
This stuff:
3x: Ez Slide (orm-d) - RVWholesalers.com RV Parts and Accessories
opinions please?
boatless is offline   Reply With Quote
Old 05-14-2014, 05:09 PM   #2
Witch Doctor's Avatar
This stuff:
opinions please?
I use a dry graphite spray. It holds up well a little costly but gives a great coating. That product will work from RV or you can go to Napa and buy there spray on white litheon a lot cheaper it will dry and not pick up grime. DO NOT USE GREASE. You will be surprised how nice they work after you apply it to the gear and I spray the whole bar teeth and sides and upper. I do it about every 4 mos. I also hit my adjustment screws and nuts at the same time.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-15-2014, 08:01 AM   #3
want a Cat 293REX
Thanks, appreciate it!
slide, slide out
