Old 02-06-2017, 03:12 PM   #1
Slide Out Repair Manual
Is there an on-line repair manual for the slides on a 2007 Forester 2941DS, specifically for the drive gear assembly?
bukhrn is offline   Reply With Quote
Old 02-06-2017, 03:19 PM   #2
Herk7769's Avatar
We have several in our library; who made the slide out mechanism?
Does it have cables or a rack and pinion system?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-06-2017, 03:27 PM   #3
No cables, the name on the gear box cover says Venture MFG., as it was replaced previously, it may very well be after market.
Old 02-06-2017, 03:37 PM   #4
Herk7769's Avatar
This is the electric motor and rack system used by Lippert and others.
Name:	Timing bolts.jpg
ID:	129340   Click image for larger version
Name:	9 Nov 2009 006.jpg
Old 02-06-2017, 04:07 PM   #5
This is what I have, the shaft is vertical, not horizontal as the Lippert you show. (The cover has been removed)
Old 02-06-2017, 06:33 PM   #6
Herk7769's Avatar
That looks like the stub shaft for the hand crank (if the motor fails).
Venture makes the gearbox and motor:
Here is their web site:
Linear Actuator Manufacturers | Linear Motion Products - Venture Mfg. Co.
Here are the actuators for your coach:
http://www.venturemfgco.com/rv-slide-out-actuators/
Old 03-20-2017, 04:33 PM   #7
Lippert hydraulic pump leaks.
My 2002 Springdale TT, Slide outs most of the time does not work because the hydraulic Reservoir leaks. Every time we go to the river where our trailer is stored and have to put 2 to 3 qts of ATF in the Reservoir. Then I have to push on the slide out while my wife pushes the button. Sometimes times it's easy and sometimes it's hard to go out & in. Does anyone knows what the problem could be? And does anyone knows how to override the system to get the slide out back in or out? LIPPERT HYDRAULIC SYSTEM.
Stewcom1 is offline   Reply With Quote
manual, repair, slide, slide out
