Originally Posted by tfmdgm
The plates I've seen is 8" wide (4"roller w/2" on each side) and the length is from the outside of the slide to a couple of inches past the rollers and 1/8" thick. Most are aluminum. I can't find a supplier with material that thickness that will supply a small quantity like I need. A couple says they can do it, but never call back with a price. I'm working with Forest River to try to get them to pay for the material.
Now that I know what they are, have you tried a metal supply business? I would think you could find 1/8" x 8" aluminum flat bar. Most places have a metal break and could cut to length, or just use a band saw to do it. Then add double sided tape to the aluminum?
I would still think galvanized flashing may be an option. 8" is quite common.
I will also check my local metal dealer for it. Thanks.
