Old 09-10-2012, 07:44 AM   #1
Question slide out sagging
i have a 2005 sun seeker 3100, the slide out is sagging and rubbing on the motor. i would like to know how to adjust the slide out. to make sure the bottow closes tight and even with the top,
jkfl is offline   Reply With Quote
Old 09-10-2012, 07:51 AM   #2
TURBS's Avatar
There should be two bolts and slide plates under the slide out you'll have to loosen the slide plates bolts and then UN jamb the adjusting bolts then adjust to your liking.
Old 09-10-2012, 08:35 AM   #3
this isnt a fith wheel so i have compartments all along the side with a 4 inch curton filling the gap between slide and compartments. i can see 2 double nuted bolts that appear to adjust lift and right even movement but with the limited vision im having trouble seeing everything. can you give a better desciption of size or location of the bolts
Old 09-10-2012, 08:48 AM   #4
TURBS's Avatar
As I don't have your make or model the adjusting portion normally remains the same.
I'd take a pic and show you but I'm at work (cough cough kinda)
Maybe dunnnc can take a pic of his adjusters so at least you know what your looking for .
Welcome to the forum
Old 09-10-2012, 09:45 AM   #5
Are these the adjustments you're referring too?
ID:	19363   Click image for larger version
ID:	19364   Click image for larger version
ID:	19365   Click image for larger version
Old 09-10-2012, 09:50 AM   #6
TURBS's Avatar
First second and third photo
See in the first and second photo were yours had been adjusted before.
Old 09-10-2012, 09:53 AM   #7
TURBS's Avatar
Last photo is to adjust in and out adjustments.
Old 09-10-2012, 10:27 AM   #8
TURBS's Avatar
Clean out pm box, it's full
Ten 4
Empty !
Old 09-10-2012, 10:39 AM   #9
TURBS's Avatar
Also adjust in small increments.
Old 09-10-2012, 12:16 PM   #10
the photos are clear but this slider does not have those components. if i had a camera i would like to show you what i see. thank you both for your help. next time i hope things are smoother
Old 09-10-2012, 12:18 PM   #11
TURBS's Avatar
Yes would be nice to see what you've got.
Old 09-10-2012, 12:19 PM   #12
TURBS's Avatar
Maybe someone with your make and model will be along to help.
