If your slide is not centered in it's opening, and thus scraping on something as it moves in and out, you might try what I did.
After making several trips in our new trailer, I noticed one of the slides had moved rearward and was no longer centered in its opening. I found four hex fasteners at the ends of the two slide tracks under the slide floor were loose as they passed through their slotted holes. I loosened them a bit more and, with the slide extended, put my back to the rear sidewall of the slide and pushed with All my might (not a lot of ”might" left in this 73 year old.) The slide moved back into it's proper place!
Tightened the fasteners, and all is good again.
Roger, Sherrill, and Harley (Great Dane)
2016 Flagstaff V-Lite 30WRLIKS [sold]
2012 F-150 XLT Screw 3.5L EB, 3.55
Air Lift AirCells, Blue Ox BX1500
