Old 02-12-2014, 11:01 AM   #11
tumbleweed1's Avatar
Let me know if it does!
2014 Siearra 355RE
Dodge 35000
tumbleweed1 is offline   Reply With Quote
Old 02-12-2014, 11:30 AM   #12
Helmsey's Avatar
I would imagine that Lippert part would work. The only issue I could see is if you dont currently have individual hydraulic lines at the pump for each slide. I would think that would need to be done so you could isolate each slide with the knobs.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 02-12-2014, 11:32 AM   #13
I need to verify what all is plumbed up front. There are a ton of hoses going into a manifold at the pump.
tone100 is offline   Reply With Quote
Old 02-13-2014, 06:00 AM   #14
jacknife's Avatar
Lippert has a sells a valve control ass that you can purchase to control which slide out you want around 80 to 100 bucks
Sent from my SCH-I535 using Forest River Forums mobile app
jacknife is offline   Reply With Quote
Old 02-13-2014, 06:10 AM   #15
leencharlotte's Avatar
I tried to order this from the factory on my 2014SAQB and it wasn't available any longer. So the dealer said they could do it. That was until the trailer actually arrived on the lot and found there was a single continuous line for all slides. Well they said they could still do it but the cost would be very high as they would have to run all new lines according to the folks they spoke to a lippert. Good news for me is that the slides have ran in same order each time so I do know the order at least
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 02-13-2014, 10:39 AM   #16
Helmsey's Avatar
Our also seem to always go in and out with the same order, and it is an acceptable order I guess. Ours goes out: bedroom, main living, and then one or the other bunk slides, also seems to come back in with the same order.
Initially I was looking to add the selector to mine but since it has bee going in and out in the same order every time I have run the slides it's off my "to do list".
2015 Chevy 3500HD
Old 02-13-2014, 11:23 AM   #17
On my 376 it goes bedroom, kitchen, bunk room and then the big living room slide. Its a pain to get to the fridge since I have to open all 4 slides.
Old 02-13-2014, 12:33 PM   #18
I agree!
2014 Siearra 355RE
Dodge 35000
select, slide, slide out
