Old 09-27-2015, 08:13 AM   #1
NKARENG's Avatar
Slide out Stablizers
Does anyone use Slide out Stablizers? Pro and cons?
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 09-27-2015, 08:15 AM   #2
nomad297's Avatar
No pros. All cons. They are a very bad idea for several reasons.
Bruce
Old 09-27-2015, 08:16 AM   #3
fonzie's Avatar
Bruce
X2
http://www.forestriverforums.com/for...uts-74318.html
Fonzie
Old 09-27-2015, 08:20 AM   #4
NKARENG's Avatar
Been searching for this answer. I had read it but couldn't find it to show DH. Makes a lot of sense. Thanks for the quick response.
2014 Dodge Ram 1500
Old 09-27-2015, 08:26 AM   #5
The slides are engineered to be unsupported and if you put any support under it and the couch settles you are putting upward force on the slide out. That can result in substantial damage.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 09-27-2015, 03:44 PM   #6
The slide rails are the structural support that was engineered to hold the slide when both in and out. Never use supports in the event of settling as others have mentioned.
If the slide appears to be sagging or the like, chances are that it may either need an adjustment (not something for the average person to do) or you have a structural issue that needs to be repaired/replaced.
If the slide is properly adjusted, it shouldn't have much bounce when fully out.
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 10-07-2015, 05:30 AM   #7
As i was extending the slides, the dinning room/kitchen slide with the residential refrig ripped the wall from the floor on the side where the refrig is. I called the dealer service center we had just left and they said I should have a support under it. I asked how can I have a support under it AS IT IS MOVING OUT?
2015 Cedar Creek
38fl Hathaway Edition
brycliff is offline   Reply With Quote
Old 10-07-2015, 10:57 AM   #8
Always Learning
That's an idiotic answer from the dealer. You should call Cedar Creek directly.
Old 10-07-2015, 12:13 PM   #9
TURBS's Avatar
I agree.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
slide, slide out
