Old 09-03-2013, 06:57 PM   #1
slide out stopped working
I have purchased a 2013 flagstaff classic super light and after our last camping trip, we managed to get the three slides in but once we got home they wonít move at all. All the fuses seem to be in order and being plugged into the house should solve the power issue.
Does anyone know if there is a breaker specifically for the slides?
And if so, where it is located?
Thanks in advance.
5ingrams is offline   Reply With Quote
Old 09-03-2013, 07:18 PM   #2
Berkshire 390QS
NO3putt's Avatar
Most slides are 12 volt as I remember. Must be another fuse, something binding the slide, motor bad or low battery. Just guessing. Let the battery charge up and try again.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 09-03-2013, 07:41 PM   #3
Triguy's Avatar
Take a look for a 30 amp inline fuse (green) for each slide out (I think, as I've never owned a unit with more than one). The first place to look is underneath by the inner frame starting a few feet in from the battery.
You probably have a resettable breaker as well. If so, there's a little button on a box you can push to reset.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
slide, slide out
