Old 07-14-2012, 11:37 PM   #1
Linnied04's Avatar
Exclamation Slide out stuck halfwayout!
Hello I just bought my first camper used. Its a 1998 sierra with two electric slide outs. When I attempted bringing my slide outs in and then back out, they got stuck and blew a breaker. After flipping breaker the slide out will no longer function at all and is stuck halfway out. Any suggestions? I'm new to the rv world and in the learning process of the ins and outs/ ups and downs of being an rv owner.
Linnied04 is offline   Reply With Quote
Old 07-15-2012, 02:49 AM   #2
jtstromsburg's Avatar
Assuming you're hooked up to 110 and it's not just a dead battery, you may have a fuse in the 12v side if the panel that needs replaced. Do you're lights and other 12v appliances still work?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-15-2012, 05:35 AM   #3
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
And...a fuse doesn't necessarily have to be in the panel. I had a Sandpiper that would occasionally blow fuses for the front jacks. After manually cranking to raise it high enough to hook up...and then manually cranking it to unhook I called my dealer and they told me to look behind the battery connector and it would be "one of those six or eight inline fuses".
I learned to keep a good supply of yellow 20 Amp blade fuses because with our Texas heat those things popped like popcorn sometimes.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 108
rjshiflet is offline   Reply With Quote
Old 07-15-2012, 06:27 AM   #4
Herk7769's Avatar
My landing gear 30 amp fuse repeatedly blew when I over extended or retracted it. I replaced it one day with an autoreset one and never looked back. Since the 30 amp fuses for my slides were also behind the battery, I replaced them as well.
Eventually I moved them when I reworked the battery compartment.
The green pigtails are my slides.
HAM CALLSIGN - KC3FFW
Old 07-15-2012, 10:40 AM   #5
Linnied04's Avatar
Red face 12v?
Where do I find the 12 volt fuse that works for the slide outs. Someone advised me it was in a different spot then all the other fuses for camper. I am set up in an rv park so I am connected to electric also if that changes anything. Please explain simply I do not understand most camper lingo yet.
Old 07-15-2012, 01:49 PM   #6
TURBS's Avatar
Fuses for slideouts could be
1) power distribution panel
2) next to or near battery
Most slideouts require a good working charged battery to operate.
Old 07-15-2012, 07:29 PM   #7
Hello,
I have a 2601ss, sometimes I have had to disconnect the battery lead(positive) to get my slide to work again. Also, you should have a tool about two to four feet long that you can attach to your slide motor to crank it in or out manually. Check under your camper, if it does not have a enclosed underbelly, follow the wires from the battery back, there is sometimes a fuse underneath.Good Luck!!
Ron H.
2013 Rockwood 8281SS
2006 GMC 1500HD 6.0L 4.10 GAS HOG!
Rochester, NY
rcnhoward is offline   Reply With Quote
