Old 08-24-2016, 11:26 AM   #1
Slide out switches
I have a Crusader Lite 30bh and have an "issue" with the placement of the slide out switches. The one in the bh is right about the light switch and it seems like whenever someone goes in there they hit the slide switch to turn on the lights. I've also had people bump the main switch in the living room if they are standing in that area.
So is there an easy way to remedy this? My daughter says to put a cover over the switches (like what you see over fire alarms and thermostats). My other option would be to pull the fuse, but I would hate to have to pull the fuse every time as we travel at least once a month to a different place.
dinosaur is online now   Reply With Quote
Old 08-24-2016, 12:12 PM   #2
Perhaps you could wire a second switch in a less accessible location and turn it off when camping.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 08-24-2016, 01:17 PM   #3
Head Rambler
Along JD's idea. If you have an unused switch in the system panel you might be able wire it to operate a relay in series with the slideout power wire(s) from the power panel.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
slide, slide out, switch
