Old 03-23-2014, 02:16 PM   #11
I contacted Carefree of Colorado and was told in order to release tension on the slide Kover II I would have to drill out rivets on the left side and spin it against the arrow direction and not sure after that, I'm unclear.The topper just doesn't seem to be under enough tension to have to release any.
TJBob is offline   Reply With Quote
Old 03-23-2014, 02:20 PM   #12
All I can suggest is you have the manual and info from Carefree. Other than that, don't know what to tell you if you think it's ok and don't want to experiment.
Old 03-23-2014, 02:28 PM   #13
I appreciate your comments Coot and I will experiment I have too, as it is now it'll end up tearing the bottom panel of the sofa off. It drags pretty bad, it's just strange that after I first installed it it was fine. it operated perfect. Thanks again!!
Bob
slide, slide out
