Old 05-05-2015, 11:57 PM   #11
Thanks again for the replies. I will use the gel and like the fact that it dries in about two minutes. I did turn the recliners to face each other, pushed them back all of the way and placed pipe insulation on the lever next to the wall. I also put vent cushions between them and the wall to protect the wall paper.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 05-06-2015, 08:42 AM   #12
Witch Doctor's Avatar
Generally expanded Gorilla Glue has little to no holding power. The foam just doesn't have anything to it.
The gel sounds interesting as it would have gap filling abilities.
the gel glue is made by loc-tight or something like that. Ace sells it. It stays where you put it in 2mins. and I think it said 24 hrs to cure completely. Try it, you will never use crazy glue again.....
Coachmen M/H
Concord
2018 / 300 DSC
slide, slide out
