Old 01-19-2015, 09:57 PM   #11
Fulltime family RVer
Platokidd PM'd me.. Here's my response that might be helpful:
Yes, I was able to push my slide to get it to move with the motor still in the tracks. You have to remove power to them. They have a wiring harness at the top of them that you can unplug. I could only reach the one. My miniature assistant got on top of the slide and crawled back to the rear one- thank God for adventurous 11 year olds.
Once there is no power to the motors, you're free to force the slide in or out. You have to do it evenly and like I said- you have to push like a mother-effer. You have to overcome the resistance of the motor AND the weight of the slide. I wouldn't want to fully retract nor extend the slide this way but a foot or so is possible- just super exhausting.
Because there is no lock once power is removed AND I could only get 1 harness reconnected. We gingerly drove to Hime Depot to buy and cut down a 2x4 to wedge up at the roof level to lock the slide in the "out" position for travel. I used some rags wedged into place to fine tune the fit.
I don't have a thread on this. It happened on our way to Florida back in December.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
ependydad is online now   Reply With Quote
Old 01-19-2015, 10:02 PM   #12
Slide out will not extend
We had a mobile RV tech come out to our campsite in Florida to replace a motor. The slide was partially deployed (about 6"-8"). In order to replace the slide, he literally took out the screws up and down the slide wall and freed the whole slide out from the camper. (It was pretty shocking how easily it came apart!)
He then had to locate the same set screw that Platokidd's email talks about. For us, it was a matter of pulling the gasket down and backing the screw out.
I don't know how you can do anything with the slide motor with the slide fully retracted. It's going to have be forced to be partially deployed. And that is disconnect the battery & shore power or just disconnect the wiring harnesses to each motor. These can be difficult to reach. And then push a little on both sides. I needed all 280 pounds of me pushing into the slide with my whole body. My father-in-law tried to help- he couldn't budge it by just leaning into it; only when we used our legs and backs could we get it to move.
Old 01-19-2015, 10:11 PM   #13
Kunaman234's Avatar
Had to Dropped off my 2013 lacrosse 303RKS last thurs. needed some warranty work done. But when I tried to open sliders, no power. I had lights microwave power but no slide out, landing gear power to jack power. Don't know if when I plugged it into my home 30amp plug. I heard small tiny spark and maybe that caused something to pop. Since the inverter is behind slide it was tough to see into. Curious to hear what the problem was. Suck having to crank leveling and tow jack manually. I'll keep you posted when I hear back from service. Sorry I have no advice but it in there now.
Kunaman234 is offline   Reply With Quote
Old 01-19-2015, 10:31 PM   #14
LKicklight's Avatar
Right now, we have both motors un-plugged from the wiring harness, of course we un-plugged the power to the circuit board earlier. We have tried now with four grown men and the slide will not move at all out.....now at a loss as to what to do, it is all the way in....the idea of drilling holes is beyond me....surely someone thought this was going to happen sooner or later....with motors disconnected I figured we would be home free, not so!!
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 01-19-2015, 11:00 PM   #15
Do you have any pictures of the outside of your slide? Can you get to the screws that hold the slide in place to the camper?
Old 01-20-2015, 11:01 AM   #16
LKicklight's Avatar
Lippert Tech.
Spoke with Lippert this morning and there answer was this, the slide was never intended to be pushed out with the motors attached, to much torque. Therefore the exterior trim removal is one approach or drilling a 1" hole where the set screw is another. The motors have such a high torque ratio moving them is almost to impossible...think I will try the 1" drill bit first of all, removing all that trim will take forever..
Old 01-20-2015, 01:10 PM   #17
Platokidd's Avatar
LKicklight, Maybe Prime time could offer some input here?
Best of luck with getting this back up and working again. If you have time take some pics of the process.
The engineer's that thought this one up should be dragged behind the wood shed
ependydad must be strong like bull
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 01-20-2015, 04:59 PM   #18
The 1" hole through the trim and into the side of the camper makes me sick to my stomach and it's not even my camper!
I'm young and fat, what can I say?
Old 01-20-2015, 06:10 PM   #19
LKicklight's Avatar
Mouldings
The exterior of the slide has metal trim surrounding the slideout....removed screws..no good, trim is actually glued on! Maybe a heat gun would losen the glue up holding, don't know did not bring a heat gun with me here to Florida....Lippert say's they did not plan anything for this situation...getting the unit home or to a repair shop is there only concern///that pretty well leaves me outside looking in....we are down and out and about ready to dump this Crusader!!!!
Old 01-20-2015, 06:54 PM   #20
The RV tech that came to me used a putty knife to break the "glue". He called it something, but I don't recall what.... maybe dicor sealant.
slide, slide out
