Old 01-25-2015, 04:09 PM   #31
LKicklight's Avatar
Sofa Slide
After beating this horse to death, I have pretty well concluded that the only way to get the sofa slide to extend is with the electric motor dead to the world, will be to drill a 5/8" diam. hole in the exterior slide trim, insert another smaller drill bit to locate the allen head set screw in the Schwntek Motor, this will relieve the motor so it can be removed from the interior of the coach as intended. To bad the factory never thought of this procedure when the coach was designed years ago. After replacing the bad motor, we should be able to extend the slide for the first time in three weeks. Will try to call Ron Green at Forest Rivers Repair Facility first thing in the morning, as I intend to begin whacking on this thing by nine AM on Monday..I see by some other threads posted this is the only path at this time given that the slide trim is screwed all the way around the slide and no one but Superman can ever get this darn slide to be pushed out.......
Pictures of this process will be documented.....
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 01-25-2015, 05:30 PM   #32
dannyabear's Avatar
My local shop has changed out mine this week. Not sure how many it took to slide it ouut but i'm gonna talk to them tommorow when I pick it up, just so i'll know for next time.I'm going to look into replacing the screww that secures the motor with a SS pin that could be removed from inside or out. The rubber gaskets should keep it from 'walking out'.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 01-25-2015, 05:53 PM   #33
LKicklight's Avatar
Pick Up Coach
Would be interested in knowing where you took it to get it repaired. If it rains here tomorrow, that will give me time to make a few more calls...Removing pin or screw from the inside would be a great idea..keep me posted..send me a private message with your number, I will do the same..kiskster
Lake Wales Florida
Old 01-25-2015, 06:04 PM   #34
Crusader's Avatar
Lake Wales Florida
Randy ...... check your E-mail
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 01-25-2015, 06:27 PM   #35
Crusader's Avatar
http://www.amlrv.com/site/wp-content...l-override.pdf
Old 01-27-2015, 10:02 PM   #36
Platokidd's Avatar
LKicklight, any more news on the slide prob?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 01-31-2015, 07:20 AM   #37
LKicklight's Avatar
Wiring issues
Looks as though we may have a wiring issue with our sofa slide after all. Checking the wiring i have discovered a short going to the #2 motor, this wiring runs under the slide out inside the coach,have no idea how to get to it short of removing the slide out complerely. Will let the dealer deal with that when we get back home on the 23rd of march. Having a sofa sitting in the middle of your living room has been an experience......Think we may be checking into another brand of 5th wheel soon. Seems as though every time we leave to go out on the road, something else pops up. We preflight everything very well, this should not being happening, as we are as anal as it comes to having everything just right...Kind of sick right now, all this money invested in something we have no confidence in any longer..
How to extend slideout when motor is not working???
Old 02-21-2015, 05:56 AM   #38
Platokidd's Avatar
Looking for an update on the slide-out issue, if there is one
nights of camping
Seasonal
slide, slide out
