Old 06-07-2014, 02:15 PM   #1
Slide out won't extend
I have a new to me 2010 Salem 26 TBUD (triple bunk beads in back) with a slide out containing the couch and dining table.
I tried to extend the slide today sitting in the driveway and it won't go out. It makes a distinct clicking noise and doesn't move. What am I doing wrong?
I've read about manually extending it, but there's no intuitive way and I don't have any special tool to manually extend it. If this is something I need to acquire, advice on that topic would be appreciated too.
Coastalbirds is offline   Reply With Quote
Old 06-07-2014, 03:40 PM   #2
pvillebly's Avatar
The switch rocks in two directions. One for in and one for out. Once it is all the way in it clicks to let you know. Same on all the way extended. Could it be as simple as rocking the switch in the other direction?
Sent from my SM-T210R using Forest River Forums mobile app
pvillebly is offline   Reply With Quote
Old 06-08-2014, 12:25 AM   #3
I'm positive that I'm moving the switch correctly, and when mine is in all the way, it doesn't click, it just stops.
Old 06-08-2014, 02:52 PM   #4
Does anyone know what system this is (like manufacturer, etc.)? This is one part of my camper that I have no infomation on.
Old 06-08-2014, 04:54 PM   #5
fonzie's Avatar
I am not familiar with your trailer but most likely you have a Liepert sliding system. Have a look underneath your outside entry steps for a protruding shaft with a pin in it or a black rubber grommet in the side of the trailer. This would be the manual operating shaft for the slide. See attached. Hopefully that is what you have. Also picture of manual handle.
Fonzie
Old 06-08-2014, 05:30 PM   #6
Our bedroom slide just did this last week. We pressed the switch up to bring the slide in and it made a ratchet sound and then pressed down for out, we did this a couple of times and it started working again. It worked fine the next time we needed to put the slide in and out. Not sure what caused it but it had done it once last year and then no problem until last week.
maconandk is offline   Reply With Quote
Old 06-08-2014, 05:53 PM   #7
Suspect a bad switch.
Old 06-09-2014, 06:59 AM   #8
Thanks Fonzie...that is what I have. I think I'm missing the piece that goes on the end of the shaft to attach a ratchet to in order to extend it manually. I suppose I'll start there.
slide, slide out
