Old 08-15-2012, 06:00 PM   #1
slide out won't slide in
when attempting to slide in the living/dining room on my 2001 sierra, the bottom wants to come in - the hydraulics are working properly, but the left hand top will not come in - like it is stuck. the result is that the entire slide starts to tipdownward on the outside, upward on the in side. The seal is not stuck to the frame - anyideas of the cause
mike
mbaggott is offline   Reply With Quote
Old 08-15-2012, 06:03 PM   #2
TeresaInCAL
TeresaInCAL's Avatar
Make sure there is nothing on top, like a stick.
TeresaInCAL is offline   Reply With Quote
Old 08-15-2012, 06:11 PM   #3
slid out won't slide in
I did check the top - nothing there - nothing seems to be holding it out
Old 08-15-2012, 06:40 PM   #4
TURBS's Avatar
have you tried to have someone help it in on the stuck side ?
Old 08-16-2012, 12:36 AM   #5
slideout won't slide in
Yes, I have tried trying to push/pull the slide to assist the hydraulics - the thing won't budge
Mike
Old 08-16-2012, 12:54 AM   #6
TeresaInCAL
Can you WD40 it???
