Old 03-29-2014, 09:20 AM   #1
Slide-outs, floor level vs raised
Why are some slide-outs almost floor level while others are raised up several inches? I am looking at some new campers and found one I like but the slide-out area is several inches higher than the main floor. Anyone know what I mean, I hope I am making myself clear?
comfun1 is offline   Reply With Quote
Old 03-29-2014, 09:26 AM   #2
spierce617's Avatar
I have a Cherokee that the slide is up about 3-4 inches. The mechanical slide unit is mounted under the slide out and bolted to the floor. The flat or level one it is mounted under the camper. They all need maintenance at times and not sure which one is better. I have owned mine for 2 years now and have only had to lube the slides and nothing more. Hope this helps you.
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
slide, slide out
