Old 03-23-2014, 07:59 PM   #1
Slide outs have no power and awning. Help
Hello,
I have a 2011 Coachmen 296REDS and when i got home today from our trip and opened the larger slide all the way the power was lost. I cannot open or close either slides now and i noticed the awning will not move either.
I checked the fuses were not blown or the breakers in the same panel.
I looked for a in-line fuse by the battery but did not find one.
Anyone know of a 30 amp reset button or something?
DjIrish is offline   Reply With Quote
Old 03-23-2014, 08:29 PM   #2
BillyBass's Avatar
Do you have a battery disconnect and is it on
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 03-23-2014, 09:36 PM   #3
No i do not have a battery disconnect.
Old 03-23-2014, 09:38 PM   #4
Do you have a DC volt meter
jwedell is offline   Reply With Quote
Old 03-24-2014, 05:18 PM   #5
Yes i do.
Old 03-24-2014, 05:29 PM   #6
It's a process of elimination. First check the voltage at the battery. It should be over 12 volts. If that checks out you should check the connections at the back of the electric panel (make sure the 115 volt power is disconnected.) You should have the same voltage as the battery. Make sure all connections are tight. The slides and awning are 12 volts so you don't need to check the 115 volt side at this time. Check back with your findings. This is not fast but it is through. Good luck.
Old 03-24-2014, 05:29 PM   #7
Triguy's Avatar
Do you have a resettable like this between the battery and slideouts?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-24-2014, 05:47 PM   #8
yes i have two of those terminals underneath the frame but how do you reset them?
Old 03-24-2014, 05:58 PM   #9
Triguy's Avatar
That type is a manual reset and requires you to push a button. In the picture, its on the right side. That button pops out when tripped.
Scott
2012 Shamrock 233S
Old 03-24-2014, 06:10 PM   #10
old guys's Avatar
You can also check for a broken or loose ground wire probably near the slide that is out. They attach them to the frame with self tapping metal screws and use an air gun to put them in. Often they get a little over torqued and snap off from the motion of the slide or the trailers over the road vibration. This did happen to us and I had no idea how we were going to get the slide back in until I noticed the loose wire. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
Old 03-24-2014, 06:31 PM   #11
This is a picture of the ones that i have.
They say short stop and i checked the voltage on both sides. 13.64v
I take it these are not the right ones.
Old 03-24-2014, 06:33 PM   #12
Here is the pic
Old 03-24-2014, 06:34 PM   #13
sorry pic not working..
Old 03-24-2014, 07:16 PM   #14
VinceU's Avatar
They should be good. You need something common to both slides. My coachmen used a seperate control to operate the motor power via relays. You may find the common switch panel voltage is missing
awning, power, slide, slide out
