Old 08-11-2013, 03:11 PM   #1
NotNearlyNormal's Avatar
Slide outs on 34QS
I have a serious problem with my quad slides which operate from from one inside switch. When I tried to open just the back three which are always first, so that I could get some things out, they stopped moving as a screaming alarm started. Once it stopped, I now show no power on battery or through electric plug in.. My slides are stuck partway out. Does anyone know what the alarm was for? I notice the big "service disconnect" switch, which I never touch is in the Off position. Is there a manual crank point to get the slides in? I have only found the one that runs the jacks, or are they connected somehow?
NotNearlyNormal is offline   Reply With Quote
Old 08-11-2013, 04:48 PM   #2
Dave_Monica's Avatar
Not sure that I can solve your problems, but I've attached the Lippert manual for hydraulic slide...that'll show you how to move them manually... http://lci1.com/images/Flyers/Owners...de-out-web.pdf
The other stuff, I'm guessing. Perhaps the noise you heard is the propane alarm when power was interrupted. Have you checked for battery power with a voltmeter or have you tried the 'On' position on the battery disconnect switch. I'd be really guessing as to why you don't have shorepower...breakers tripped?
Dave
Old 08-12-2013, 08:57 AM   #3
Thanks for the manual. I finally know where to look for the manual retract. When my rv was broken into we lost some of the documentation. Trying to find out how to extend/retract manually was driving me crazy. Hopefully, I can get them in so that I can get to the shop and have them find my electrical problem.
