Old 06-09-2015, 05:46 PM   #1
Slide-outs won't slide out.
The 3 slide-outs on my 2013 CC 5th wheel won't slide out with the generator on. They came in fine this AM when hooked to shore power. I don't have the levelers down. Does anyone have any suggestions?
Gaasb is offline   Reply With Quote
Old 06-09-2015, 05:55 PM   #2
Will they slide out on shore power?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 06-09-2015, 06:13 PM   #3
I don't know...I just pulled into a walmart to overnight camp. Wouldn't the generator be the same as shore power for the slide-outs to extend?
Old 06-09-2015, 06:24 PM   #4
It's not the same if the transfer switch is not working right. Do other things like microwave and ac work?
2016 Flagstaff 23lb
Old 06-10-2015, 12:33 PM   #5
Slides run off battery. May not be charged
Harkerr is offline   Reply With Quote
Old 06-10-2015, 12:41 PM   #6
We just had one slide that would not extend. In the basement there was manufacturing trash that worked its way into the rack preventing it from moving. The pinion gear lost 4 teeth trying to move the rack.
This is probably not your problem since all 3 slides don't move. But wanted the group to make a mental note of my problem in case of future slide problems.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
slide, slide out
