Old 07-06-2015, 06:43 PM   #1
slide plates on schwintek slide out
just curious. has anyone installed the metal slide out plates on a slide with the schwintek in wall motors. any feedback or comments would be appreciated.
uralman is offline   Reply With Quote
Old 07-06-2015, 09:46 PM   #2
Yes I have. I have taken the whole system off and replaced. What do you need to know?
Rooftop is offline   Reply With Quote
Old 07-06-2015, 09:56 PM   #3
Does the thickness of the plates themselves affect the interface of the motor and the gear on the side of the slide.
Old 07-07-2015, 05:32 AM   #4
Yes it does. Are you thinking of changing what the rail material is made of?
Old 07-07-2015, 07:04 AM   #5
I am concerned that by installing the metal plates which are about 1/8" thick it could damage the slide gear rails. Or is 1/8" not enough to make a difference.
Old 07-07-2015, 07:21 AM   #6
Can you explain what you mean when you say side plates? I want to make sure we are thinking of the same part. A picture would even be better
Old 07-07-2015, 09:20 AM   #7
The aluminum plates that would be attached to the bottom of the slide on top of the rollers
Old 07-07-2015, 09:52 AM   #8
Okay now I know what you mean. Yes it might affect it. There is some play in the system but it could affect it. This system comes pre assembled and is screwed to the slide and then screwed to the trailer. Any variation up down and or left right after slide is installed could misalign the track.
Old 07-13-2015, 01:35 PM   #9
I was thinking of using just some 18ga steel because its thinner. That black plastic on the bottom of the slide is already wearing out.
wickedwyrm is offline   Reply With Quote
slide, slide out
