Old 04-18-2018, 02:48 PM   #1
slide problem
have 2015 Sabre. When I move the slide out that has the dinning table and recliners it will go so far and then there is a load clunk. It will continue after that one load clunk. No clunk when retracting. Could I have a broken tooth on the gear?
jrmorris is offline   Reply With Quote
Old 04-19-2018, 07:01 AM   #2
SeaDog's Avatar
Some slides (like mine) make that noise. Inspect both sides of the slide gear rack and the gear pack itself for tightness and see if any teeth have been broken.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-19-2018, 11:37 AM   #3
slide
thanks I will check that out. If it was a broken tooth I would think it would do the hesitation and "clunk" going in and out, not just going out. Thanks again
slide
