Old 06-05-2014, 09:46 AM   #11
Brother Les's Avatar
Good suggestions. If this was my unit, I would only put the 4 screws to through bolts for now and make sure of the clearance inside when running the slides out. Please keep us posted.
Brother Les
Old 06-05-2014, 10:25 AM   #12
Incheon, S. Korea
BigBaron's Avatar
If those screws are the same ones they use at Viking/Coachmen, I can believe that they broke.
The screws that hold down the roof on our popup broke on the second trip!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 06-05-2014, 11:16 AM   #13
sammonilla's Avatar
Thanks for all of the input. Im currenty working on the repair for the slide. I have thru bolted the affected area and am now in the middle of replacing all of the broken, missing and normal screws with new stainless hardware. I should be done this weekend and I will post all of my pic's from start to finish. Sofa the hardest part has been trying to extract the broken off screws that are still in the frame. I would have had this done sooner but only have a few extra hours here and there to do the repair. Sofa I have about two hours into the repair and it is going good. Two hours and about three beers!!!!
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 06-05-2014, 07:32 PM   #14
Displaced2's Avatar
Had similar problem on 2013 Lexington dinette slide.
They talked to FR and was told the current spacing is too wide. To install hex head screws closer and readjusted slide stop. Have not used it yet but TRUST my guys completely.
Call and ask. Can't hurt.
Displaced2 is offline   Reply With Quote
Old 06-08-2014, 09:44 AM   #15
sammonilla's Avatar
Slide out is fixed!!
OK, I got the slide modified and fixed yesterday. Thanks for old coot, and brother less for your input. I just needed a little shove into the right direction before I started to drill holes into the TT. So far I have replaced 8 broken screws from both sides of the slide out. I thru- bolted the lower left corner with 1/4-20 SS nuts and bolts and replaced all of the other screws with larger SS screws. The total repair took about three hours and about six beers!!!. The pics are from before I cut off the excess from inside of the TT. The slide now is quiet and smooth when operating. here are the before and after pic's. Notice all of the broken screw heads on the tool cart.
Name:	sammons phone 6.6.2014 104.jpg
ID:	54634   Click image for larger version
Name:	sammons phone 6.6.2014 106.jpg
ID:	54635   Click image for larger version
Name:	sammons phone 6.6.2014 109.jpg
ID:	54636   Click image for larger version
Name:	sammons phone 6.6.2014 157.jpg
ID:	54637   Click image for larger version
Name:	sammons phone 6.6.2014 158.jpg
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
Old 06-09-2014, 11:19 AM   #16
Very good job on the inside. Grind or cut off a little more of the bolt sticking through and then cap the bolt end off with a cap.
Vestil - Plastic Bolt Caps
Brother Les
slide
