Old 08-22-2015, 09:26 AM   #1
ryand's Avatar
Slide room wiring support harness
Anyone know if this wire harness support whatever it's called is available? It broke at the frame and now hangs down when the slide is closed.Click image for larger version
Name:	ImageUploadedByForest River Forums1440253568.153437.jpg
ID:	86520Click image for larger version
Name:	ImageUploadedByForest River Forums1440253589.379950.jpg
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 08-22-2015, 09:29 AM   #2
davel1971's Avatar
it will break again if replaced with same thing. Both of mine broke in the first few months. I attached them to the frame with galvanized door hinges. Gives it a pivot point. Been working great for last 2 years.
David & Lynn
Old 08-22-2015, 09:32 AM   #3
Did the same thing.I used a 3" tee gate hinge.Fastened the long part to the strap with two bolts and nuts.Screwed the other part of the hinge to the trailer frame.Been on there going on two years and going strong.
DaveandSue is offline   Reply With Quote
Old 08-22-2015, 10:11 AM   #4
ryand's Avatar
Thanks guys. Great ideas!
Old 08-22-2015, 11:23 AM   #5
hkreck's Avatar
Hey guys can you post some pictures? As they say a picture is worth a thousand words. Thanks
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-22-2015, 11:33 AM   #6
Pictures please x2
Handydc is offline   Reply With Quote
Old 08-22-2015, 02:50 PM   #7
Mine did the same exact thing after 5 months of use. I had access to some old rubber conveyor belt material. I cut strips out of them and replaced the plastic ones with those.
Has been working very well so far after 3 months and almost every weekend camping putting the slides in and out.
JoeNanMinn is offline   Reply With Quote
Old 08-22-2015, 05:30 PM   #8
Jerry01's Avatar
Originally Posted by ryand View Post
Anyone know if this wire harness support whatever it's called is available? It broke at the frame and now hangs down when the slide is closed.Attachment 86520Attachment 86521
Lippert makes them. Both of mine were broke probably since day 1. We just didn't see it until after a few weeks. The way it was mounted explains a lot. Had it replaced and so far so good. I would love to see some of the "fixes" as well. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
roo, slide, wiring
