Old 12-12-2008, 08:55 PM   #1
Slide sticking
Does anyone know how to adjust the slide stops? We have a 8524 rls Flagstaff 5th wheel.
Our slide wants to click or ratchet at least 20 times before it will start to go out when it sits overnight closed. After it finally goes out it works fine until the next time you want to open it. I have been closing it and then going back out for just a second and it will not stick. Slide lube does not seem to help at all.
Any suggestions?
thanks ,
travis
murrayflagstaff is offline   Reply With Quote
Old 12-13-2008, 02:08 PM   #2
Here is another link on slide adjustment which may be of help.
Top slide seal moves forward
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 12-14-2008, 12:36 AM   #3
John U
Thanks, I think it might be the closed stop, will try to check out tomorrow.
Travis
Old 12-14-2008, 08:24 AM   #4
Woody 01's Avatar
Try checking the Water in your Battery. Mine was doing the same thing & I found the Batt. water was low and there was not the amps to run the motor at full power. Just a thought
Steve & Nicole Wood
Luke 10 & Morgan 7
2003 Rockwood 8281SS 5er
2002 F-250 Super-duty
Woody 01 is offline   Reply With Quote
Old 12-16-2008, 09:33 PM   #5
Thanks for all the help. The battery water was down just a little.
thanks
