Old 05-25-2013, 03:39 PM   #1
tclcyl's Avatar
Slide stopped working
We are camping this weekend and as we were setting up, my rear slide was almost out and it stopped. It's as if there is no power going to it. I got the manual crank out and got it completely out. Now I am concerned what to do when we start to pack up on Monday. Any ideas as what to check? I checked fuses and all were good. The side slide is still working fine. It is a Shamrock 25RS. Purchased new in February so will be under warranty but if I can't get it in how do I get it to repair shop? Thanks in advance for your help.
tclcyl is offline   Reply With Quote
Old 05-25-2013, 08:09 PM   #2
H2oski
Do you have a multimeter? Check and see if you have power at the switch. If no power it may be a fuse some where. If you have 12v is the switch good, power coming out to the motor?
If all else fails, enjoy your weekend and then when it's time to go get the manual crank and crank it completely in. Good Luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 05-25-2013, 08:33 PM   #3
VinceU's Avatar
Turn the crank the oposite way! Which fuses were good? Slide power supplies are often inline resetable type or circuit breakers maybe 30-50 amps.
Old 05-26-2013, 09:53 AM   #4
tclcyl's Avatar
My main concern is my crank is only 2 feet long and my slide is a king size bed. I don't think I will be able crank it all the way in.
Old 05-26-2013, 09:59 AM   #5
Wanna Be Camper
SaskCampers's Avatar
Is your motor for the slide visible under the slide? If so there shouldl be a fuse in the line close to the motor, it probably blew.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 05-27-2013, 01:36 PM   #6
tclcyl's Avatar
I got it!! I had to call the dealer this morning and they pointed me to where the fuse was located. It is located near the battery on the trailer tongue. one of the 30 amp fuses was blown. I made it home and purchased some replacement fuses on the way. I replaced it and opened up the camper to unload and the fuse blew again. I will be setting up an appointment with the dealer on our trip for Independence Day week because we will be going right by there on our way. Hope they can figure out why it is blowing the fuses. Thanks for everyone's help!
Old 05-27-2013, 02:20 PM   #7
VinceU's Avatar
Suggest bad motor or slide mechanism binding. Any groans oe scrapes? My bet is on the motor.
Old 05-27-2013, 07:54 PM   #8
tclcyl's Avatar
Nope no groans or scrapes. It only is happening when extending the slide not retracting it.
Old 05-28-2013, 07:33 AM   #9
VinceU's Avatar
Need someone who can measure DC current draw, and voltage drop, can determine if near normal or excessive, will help figure if motor is weak or excess resistance encountered.
Old 05-28-2013, 07:42 AM   #10
Herk7769's Avatar
Slides blowing fuses "typically" means:
1) slide overloaded - kitchen slide notorious
2) Slide needs lubrication
3) Slide seals "sticky" (clean with slide seal cleaner)
4) Slide seals frozen (happens after a rain that freezes at night)
6) Lubricating slide mechanism with "grease" that gets dry and sticky with road grime. (Clean with BrakeClean and lubricate ONLY with dry lube or graphite spray.)
WAY down the list is the motor itself. (and I mean way down)
HAM CALLSIGN - KC3FFW
