Old 07-11-2018, 02:20 PM   #1
Palinduff's Avatar
Slide stops intermittently
Having a slide / battery issue on an older unit (Peak). The slide goes out part way and then stops, but goes again when you keep pushing the switch. Charged the battery, a two year old Costco 27, and it shows 13.2 when fresh off the charger, but quickly drops to 12.8. When sliding it shows 10.8 at the motor. There is solar attached and it shows 13.2 at the switch always. I cleaned the posts and also clipped the wires and replaced the terminals, there was some corrosion but this didnít help. Does the same when bypassing the switch. Going to try again tomorrow with different batteries. Seems like there is a voltage loss along the line, or maybe a weak battery.
Palinduff is offline   Reply With Quote
Old 07-15-2018, 01:48 PM   #2
Palinduff's Avatar
It was the 20 amp auto reset fuse. It must have been weak. The slide is well lubricated now.
2017 F150 Eco Boost, SC, 8' Box, 4X4
Max Tow (3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2000 Honda EX 400
slide
