Old 07-27-2014, 03:03 PM   #1
asquared's Avatar
slide stuck out
Help. We just got back from our maiden voyage with our 2014 Sabre 34REQS-6. We stopped by the house to off load our stuff before putting it back in storage. DH ran the bedroom slide out to access the closet. When he went to bring it back in there is no power to the slide motor at all. No click, no noise, nothing. Fuse looks good. It is the roller type slide. He was able to push it in some of the way but not all the way. My driveway is a big hill so I can't disconnect and leave it here until repaired and I need my truck to get to work tomorrow. Any suggestions? If it helps, I have noticed some thumps when it goes in and out prior to this but could never find a reason. Dealership said thumps were normal. Thanks.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-27-2014, 03:24 PM   #2
Ford Idaho's Avatar
Have you tried using the manual wrench/tool yet?
Old 07-27-2014, 03:25 PM   #3
Witch Doctor's Avatar
Is it the slide with the motor above and has 4 cables that extend with it? On the outside? Is the motor above the slide?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 07-27-2014, 03:54 PM   #4
asquared's Avatar
Ok so here is where we are now... slide motor quit because cords pulled out of connector. We reconnected it but now slide is off track. The motor and slide mechanism are under the bed inside the trailer. When you try to go out your hear grinding, when you try to come in you hear it try but nothing catches. There is no manual crank for this slide. When we asked the tech during pdi how to get non functioning slide in, he said you get a couple of people and push it in.
2014 Sabre 34REQS-6
Old 07-27-2014, 03:58 PM   #5
asquared's Avatar
I was able to pull it far enough forward that it was level enough to chock it and drop it. I will now be calling dealership in the morning and telling them to come fix it. This happening in addition to the other issues we found between pdi and this weekend have me more than a little worried and angry. I knew there would be break in issues but it really is starting to add up. I will give the dealership and forest river a chance to make it right before I get too negative though.
2014 Sabre 34REQS-6
Old 07-27-2014, 04:08 PM   #6
Ford Idaho's Avatar
How far out of level was the trailer when you ran the slide out?
Old 07-27-2014, 04:10 PM   #7
asquared's Avatar
Not bad, just a little nose high. We usually park before it gets to out of level. We used to run the slide on our tt on the same hill all the time. No issues.
2014 Sabre 34REQS-6
Old 07-27-2014, 06:25 PM   #8
asquared's Avatar
Here are some pictures of the slide mechanism. What kind do I have ?
The first 4 are under the bed in the master.
This is underneath the outside of the slide.
This is the slide stuck halfway in.
2014 Sabre 34REQS-6
Old 07-27-2014, 06:43 PM   #9
fonzie's Avatar
If it has cables, it could be an Accu-slide? Here is manual
Fonzie
Old 07-27-2014, 06:52 PM   #10
asquared's Avatar
No cables just gears on the inside with a bar that goes across Between the two gears. it has rollers on the outside. I have not seen this set up before.
2014 Sabre 34REQS-6
slide
