Old 07-08-2015, 08:41 PM   #1
Slide Topper Malfunction
As anyone had this happen to them? The unit is a 2015 Windjammer 3006WK and the dealer just tensioned slide topper. Went to open slide for first time in a while and heard a loud pop. Went to investigate and found the topper up over the trim of the slide with the front bracket bent as seen in pictures. At closer investigation, I found two screws missing out of each bracket and not sure if that had affected its operation. It also cracked some of the trim work. The unit is still under warranty and have already contact dealer. Just wanted some additional input.
ID:	82410   Click image for larger version
ID:	82411   Click image for larger version
wingfield4601 is offline   Reply With Quote
Old 07-21-2015, 08:40 PM   #2
Well, I guess I'm the first this has happened to since there hasn't been any comments. Unit at dealership for repair, so we'll see what happens.
Old 07-21-2015, 08:54 PM   #3
toslow's Avatar
i can't believe the level of hacks at the rv dealers, seems like lie everyone on this forum has a story or two to tell
haven a blast
toslow is offline   Reply With Quote
slide
