Old 09-18-2012, 08:30 PM   #1
Dallas Texas
TexasBBQ's Avatar
Slide topper replacement
This weekend I'm replacing the fabric on all three slides. I was curious for those that did it which technique did you use and any lessons learned?
Technique:
A- Removed the roller tube from the brackets to unwind/replace fabric
B- Partially moved the slide out, lock the roller tube to unwind/replace fabric
C- Fully extended the slide, lock the roller tube to unwind/replace fabric
D- Other
E- Don't remember. Had too many
Cheers
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 09-25-2012, 12:28 PM   #2
Dallas Texas
TexasBBQ's Avatar
With so many responses I decided to post an update. Got all three slides changed. Two were done fully extended but the last had to be brought in a little because I couldn't reach the main wall.
It went fairly fast. Unwound the topper, put a hex key in the hole to prevent it from winding back up, pulled off the old and installed the new.
ID:	19885   Click image for larger version
ID:	19886   Click image for larger version
ID:	19887   Click image for larger version
2004 Cardinal 33CKT
