Old 06-21-2015, 11:58 AM   #1
Slide went out crooked on 3rd trip
Our slide for U shaped dinette on or Forester 2501 worked fine for the first 2 trips but I noticed that while the wall on the drivers side had a 3 in space from top to bottom, it was closer at the top than the bottom on the pantry side.
We put the slide out this time and the molding at the top dragged against the side of the pantry and cracked at the top.
From the outside the slide is 19 in out at the bottom and only 17.5 in at the top but it is fully extended
To get it back i without further damage we had to unlevel the unit so the front was lower 2 in.
Any thoughts?
suscamper is offline   Reply With Quote
Old 06-21-2015, 12:09 PM   #2
Name:   ImageUploadedByForest River Forums1434906498.264664.jpg
Name:   ImageUploadedByForest River Forums1434906516.990350.jpg
Name:   ImageUploadedByForest River Forums1434906529.826820.jpg
Old 06-23-2015, 10:16 AM   #3
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
Go to you tube and look up the type of slide you have. Some great videos that cover all types. Also check your wires under slide at control box. I had same issue with new m/h, wires come loose during travel. Plus once you start to open or close slide, never stop pushing until travel is complete. When you stop it throws the motors out of sync, but fairly easy to resync, just apita
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 07-09-2015, 08:58 AM   #4
I am having the same problem with my new 2015 Forest River Forester 3011DS should I let slides out before using automatic leveler or before. If I level it before, I get binding and wall rub at the top of the main slide.
Name:	Unit leveled.jpg
ID:	82444   Click image for larger version
Name:	Unit unleveled.jpg
squeaky17 is offline   Reply With Quote
Old 07-09-2015, 09:30 AM   #5
That is only on the schiwntech slides. I don't see the racks on the slide so it must be another. Op needs to ID the type of slide.
harderd is offline   Reply With Quote
Old 07-09-2015, 09:57 AM   #6
Witch Doctor's Avatar
I'm confused not hard to do, but you did it. Never use your slides until you are level, they could bind. If they are binding and you know that you are level then they need to be adjusted....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
roo, slide
