Old 04-29-2018, 02:20 PM   #1
Slide won't come in
Help!! We've got a 2011 Roo 23ss. Went out today to put the slide in, nothing! Everything else in the camper works. Awning, fridge, a/c, heater, radio, all the lights except the one over the kitchen. I checked all the fuses, reset all the breakers in the panel, checked the fuse outside under the frame. all good. I tried manually moving the slide in with the crank on the electric motor. It's very difficult to turn, and the slide doesn't move but the motor itself went all cockeyed. And when I try to manually pull it in, itís hard to turn, and the motor clicks with every small turn of the crank, and it twists either out or in at bottom, depending on whether Iím cranking clockwise or counter clockwise. We're due to leave next Friday for 5 days at Watkins Glen, and this is my only day off between now and then.
Charlell8 is offline   Reply With Quote
Old 04-29-2018, 02:24 PM   #2
SeaDog's Avatar
Check along the frame rail from the batteries and see if there is a tripped broker if so push the reset and see if the slide doesn't come in. I would be very careful cranking on a slide where you had to force something.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-29-2018, 02:33 PM   #3
I looked along the rail, all I see is a 30 amp fuse. Would it look like a standard breaker?
Old 04-29-2018, 02:40 PM   #4
If you have a remote control, try closing with the remote. I've seen cases where either the control panel switch or remote would not operate the slide properly. If neither works, check for a blown fuse. I don't have your model TT so I can' help with locating the fuse.
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 04-29-2018, 02:49 PM   #5
No remote.
Old 04-29-2018, 04:11 PM   #6
bikendan's Avatar
There's a 30 amp slideout fuse, under the slideout itself.
You have to crawl underneath.
I know cause I owned a 2007 23SS.
Equalizer WDH
Old 04-29-2018, 04:34 PM   #7
Under the slide inside or out?
Old 04-29-2018, 04:56 PM   #8
bikendan's Avatar
Outside underneath the trailer.
Should be in a rubber/silicone cover and near the slide side frame rail.
Don't think you can crawl underneath the slide out, from inside.
Equalizer WDH
Old 04-29-2018, 05:22 PM   #9
I found that one. It looked fine, replaced it anyway. Nothing.
Old 04-30-2018, 01:13 PM   #10
Palinduff's Avatar
This happened to my father, and it turned out that the battery terminal and cable needed a good cleaning. Other things worked, but the slide wouldn't move.
2017 F150 Eco Boost, SC, 8' Box, 4X4
Max Tow (3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2000 Honda EX 400
Palinduff is offline   Reply With Quote
Old 04-30-2018, 07:16 PM   #11
I stopped for gas, and the DW had to open up a slide to get something out of our Roo. Thought we were stuck, But when I started my truck engine and disconnected the trailer electric, then replugged it, the slide went righ in. Hope its something simple like that for you. Good luck
Bobrmirch is offline   Reply With Quote
Old 04-30-2018, 08:14 PM   #12
So my son in law checked all the electrical from battery to motor. All good. He disassembled the motor housing, the motor appears seized. Couldn't turn the spindle on the motor at all by hand. He took out a plastic gear, reassembled the housing and I was able to move the slide in and out with the crank. It's a Thomson-Saginaw motor. The company appears to be out of business. Does any one have any idea on a replacement?
slide
