Old 04-01-2015, 07:07 PM   #1
slide won't go out
I have an2011 puma rear bedroom slide won't go out.worked yesterday .the motor works but slide won't move.could it be twisted or something? I have it plugged into garage but no battery connected.front slide works fine.any suggestions? New to the slides so anything will help
tuner is offline   Reply With Quote
Old 04-05-2015, 10:10 PM   #2
New to Forest River
Roving Ron's Avatar
We had the same issue with our Rockwood 2703WS. The problem was a faulty adjustment on the slide actuator which resulted in the internal mechanism coming apart. If so, you will need to take it to a dealer and have the actuator replaced. (It cannot be repaired.)
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
Old 04-11-2015, 12:32 PM   #3
Brother Les's Avatar
You must have a good battery to move the slides. The converter will not put out enough juice by itself to move.
Brother Les
slide
