Old 04-06-2015, 08:51 AM   #1
mikeoller's Avatar
Slide won't retract
I have the pathfinder elite 404rb, 4 slides, 3 of the slides work perfectly..one will not budge. Are there separate motors for each slide where i could manually retract the slide? It is stuck extended so i can't take it anywhere till i get it retracted. we have had the unit only about 6 months, no trouble till now. My usual procedure is to plug into shore power (at least 110v), shut off engine, lower jacks, then extend slides. Worked fine up till this last weekend when we were headed out. Fortunatley it stuck at home so not on the road. Operator manual is no help for manual operation proce(if that's even possible). Help? And thanks.
Mike & Sharon
Furever Coaching -lots of foster dogs
2014 Pathfinder Elite 404rb
2012 Ford F150 4x4 Lariat, Ecoboost
2009 Harley Davidson Road King
mikeoller is offline   Reply With Quote
Old 04-11-2015, 12:26 PM   #2
Brother Les's Avatar
did you get your problem fixed?
Brother Les
slide
