Old 07-16-2018, 06:12 PM   #1
Slideout adjustments help needed
I created a previous post about one of my slides not sealing at the inside top when extended. I tried to adjust it by repositioning the jam nut on the slide rod that pulls in and pushes out. Not much luck. I was looking at the vertical bolt and noticed on that slide it isn't even touching the bracket. See pictures. Others are or close. Not sure what to adjust to pull the inside top out. Click image for larger version
ID:	179884Click image for larger version
ID:	179885Click image for larger version
ID:	179886Click image for larger version
OKI Marine is offline   Reply With Quote
Old 07-16-2018, 06:35 PM   #2
SeaDog's Avatar
Ok first the vertical bolts with jam nuts should be tight against up against the flange on the slide box and the jam nuts tightened. Now to bring the top inside out against the seal you need to loosen the two bolts you see in the bottom picture and lower that portion a little using the vertical bolt I mentioned. Only make small adjustments and then recheck. Let the form know how it goes. The day before put some PB Blaster where the flanges meet.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-16-2018, 06:40 PM   #3
Cyber Phrenologist
Radio's Avatar
I wrote this some 10 years ago but it does not address your specific issue.
Bummed out: Slide room out of alignment...
I would try adjusting ONE THING AT A TIME marking with a paint pen so you can put it back exactly where it was when you don't get the desired result. As in the above article, the desired adjustment may be somewhat counter intuitive.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
slide
