Old 04-15-2018, 04:48 PM   #1
Slideout awning and Jacks not working
Help. I have a 2018 Forest River Wildwood 27dbk and the slideout, awning and jacks aren't working. The fridge microwave and radio aren't working.
Newonwer is offline   Reply With Quote
Old 04-15-2018, 04:53 PM   #2
Who Dares, Wins
doc73's Avatar
Are you hiked to shore power and does it work.. Awnings and Jack's are 12v (possible for fridge as well), micro is 120... Check power pedistal breakers. Check breakers on your panel. Two systems here so if they are both out check the main connector first. Also want to find the resettable breaker for the 12v side. It is usually under the tongue area and is a little silver box and a tiny black button to reset.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-15-2018, 04:56 PM   #3
I can't get to the panel yet. Need to manually move the slide out. I saw that silver box. Will try that all tomorrow. Thank you.
Old 04-15-2018, 05:08 PM   #4
Who Dares, Wins
doc73's Avatar
Does the pedistal have power to make sure you're getting 120 to the camper?
2015 ChevyHD D-Max
Old 04-15-2018, 05:54 PM   #5
What do you mean by 'pedestal? Sorry I'm new to all of this
Old 04-15-2018, 05:58 PM   #6
Who Dares, Wins
doc73's Avatar
Are you plugged into the power plug with the campers heavy extension cord? If not not of the 120v items will not work.
Depending on how long the camper sat the battery could also die was sitting. So no 12v power.
2015 ChevyHD D-Max
Old 04-15-2018, 06:14 PM   #7
Yes we are plugged in with the power cord. The battery has a full charge.
Old 04-15-2018, 06:27 PM   #8
Who Dares, Wins
doc73's Avatar
Ok than I would start with fuses and breakers to ensure juice is flowing. Do you have any interior lights?
2015 ChevyHD D-Max
Old 04-15-2018, 06:33 PM   #9
Yes we have interior lights. I found where I can get the slide out open manually. I will try that tomorrow so I can get to the panel.
Old 04-15-2018, 06:54 PM   #10
Who Dares, Wins
doc73's Avatar
Ok, I'd look at the breakers and check those resettable breakers underneath. They can trip some times without reason.
2015 ChevyHD D-Max
Old 04-15-2018, 06:58 PM   #11
Will do. Thank you
Old 04-16-2018, 11:15 AM   #12
Went back to the camper today. Manually moved the slideout so I could get to the fuse box. Took out the 30 amp fuse and replaced it with a new one and everything is working fine now. Thank you for all of your help.
Old 04-16-2018, 11:38 AM   #13
Just as confused as you
Scrapper's Avatar
Since your new to all of this your furnace, refrigerator control board, jacks, slide outs, and lights all work from 12vdc. Air conditioner and microwave works from 120vac. The fridge will run on 120vac or propane (LP), but if the control board doesn't have 12vdc it will not run on either. Also, your water heater runs on LP or 120vac, the WH control board runs on 12vdc.
Check out these links.
Disclaimer: These links and articles were compiled by wmtire, a site team member of forestriverforums (FRF). If you give thanks, then give it to him. I had nothing to do with gathering the information, I’m just passing it along.
“I always recommend these following links to newer RV owners. It explains a RV's different electrical systems, as well as what works off of 120 volt AC vs. 12 volt DC. Not knowing your RV experience, The below is a copy and paste, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.” - wmtire
Basic electric:
The “12 Volt Side of Life” file is on Forest River Forums in the Library > Power and Electrical section in the light green bar at the top of the page and is a download and is found here. Forest River Forums - Downloads - 12 volt side of Life
Basic RV Electricity - RV Information (RV Maintenance)
https://www.rvtechmag.com/electrical/chapter3.php
RV Electric
12 Volt DC Circuit Breaker with Manual Reset
Converter or Inverter (they are different)Electrical Management System (EMS) or Surge ProtectionWhat Surge Protector is best for my RV? | Learn To RV
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
More reading so you understand the different electrical systems of your RV.
Installing a dedicated 30 amp RV outlet at home:
How to wire a RV 30 amp outlet
Suburban water heater (if applicable to your RV):
Suburban's electric switch and much more
Suburban Water Heater Video Guides
Water Heater bypass/crossover valves:
NO (OR LUKEWARM) HOT WATER -Please read first
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
Propane Cylinders (Refilling vs Exchanging)
Propane automatic changeover regulator
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 04-16-2018, 02:48 PM   #14
That's really good information. I've got it all set now. Thank you.
Old 04-16-2018, 05:51 PM   #15
Bene Gesserit Rule
Murbella7's Avatar
Having interior lights working is not an indication of the shore power working for you. Lights, like most things, run off the batteries. If you have a mains powered device, test it.
Murbella7 is offline   Reply With Quote
awning, jacks, slide
