Old 03-19-2017, 10:50 AM   #1
Slideout inside wiper/seal repair
I have a 2015, surveyor 226RBDS. My kitchen slide out top seal wiper has come loose. (Half off) it appears to have been stapled. They won't go back in. It seems they are hitting the aluminum frame. Can I just glue it? And what kind of glue do I use? Or what is the best way to reattach it? So that it doesn't work loose again.
Renlissa is offline   Reply With Quote
Old 03-19-2017, 07:12 PM   #2
SeaDog's Avatar
If you are talking about the gasket on the outside of the box that the slide flange presses up against that gasket is not designed to go in the space between the box and sidewall but rather rest on the box flush to the sidewall. Google for the adhesive to reattach, I would also staple. this may be a job for an RV mobile repair tech.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-19-2017, 10:01 PM   #3
I'm talking about the inside, attached to the wall above the kitchen slide out behind the facia board. Not outside.
repair, seal, slide
