Old 05-21-2016, 11:48 AM   #11
270S's Avatar
Originally Posted by Ida Ratherbe Camping View Post
Dealer got your money, now get in line with the rest of us. You will find that doing and fixing it yourself is a lot more satisfying and better quality than you will get from dealer or factory.
My experience, your results may vary. Congrats on new unit.
I am very capable, but having documentation (electrical diagrams) is critical to easier problem solving. Aside from getting parts under warranty (should that ever be necessary), I plan on doing everything myself.
'17 270S
270S is offline   Reply With Quote
Old 05-22-2016, 05:11 AM   #12
Great attitude
And this folks, is why the manufacturers keep pushing poorly designed, engineered and assembled motorhomes and travel trailers - the expectation that consumers will just put up with it and fix it themselves.
There is nothing satisfying about spending a boatload of your hard earned money on a POS that breaks down as you travel and you cannot get a dealer to fix it (especially under warranty) - because "you did not buy it from them". I bought a Toad partly because I will probably need it to go get parts for the MH while traveling.
I'd rather be camping too, but there is so much to fix on my MH, I spend way too much time fixing it - which leaves a lot less time to enjoy it. It's too bad - the traveling is fun, but the constant worry of "what's going to break now" takes much of the fun away.
KatanaPilot is offline   Reply With Quote
Old 05-22-2016, 05:23 AM   #13
Mainframe's Avatar
These work nice, make sure it is the long blade one, parts stores usually stock them. It's a curcuit breaker so you don't have to keep crawling around under the rig to change fuses, just wait a little bit and it resets.
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 05-22-2016, 06:02 AM   #14
Is there a "NAPA" part # for this item? Auto part stores look at you like you have 2 Heads when asking for this part! Youroo!!
Old 05-22-2016, 09:24 AM   #15
raspivey's Avatar
That doesn't take much...had to find an exhaust flange gasket for an aftermarket exhaust system. Couldn't fathom that what was in their book for that year and model wouldn't work.
slide, slide out
